NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp KCS Award
NetApp Knowledge Base
Element per-node UI login attempt fails with 'errors.genericLoginFailure' message
79
Visibility:
Votes:
0
Category:
element-software
Specialty:
solidfire
Last Updated:
Applies to
  • Element Software
    • 12.2 or 12.3 cluster that was recently upgraded from 11.3
Issue
When attempting to log into the Element per-node UI (https://<node_management_ip>:442) of a given storage node:
  • the redirect to the login prompt at https://<node_management_ip>:442/hcc/login succeeds but:
  • the actual login attempt fails with the following error regardless of whether the correct credentials are entered:
Error text:
Example:
Alternately, the login dialog box may not load, and instead the following error displays:
{"error":"Cannot redirect to the authorization endpoint, the configuration may be missing or invalid."}
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
