NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
Drive failed with state DriveMissing
606
Visibility:
Votes:
0
Category:
element-software
Specialty:
solidfire
Last Updated:
Applies to
NetApp Element software
Issue
  • One drive is failed and shown under ClusterDrivesFailed section on the Cluster UI
  • NetApp SolidFire Active IQ and Cluster UI shows 1 drive(s) with state: "DriveMissing" driveID: <ID> alert with the error code driveFailed
  • iEEvent entry at the time of the issue with a similar output can be found in Events
{ "throwFile": "shared/BasicFile.cpp", "throwFunction": "size_t solidfire::BasicFile::ReadRaw(uint8_t*, off_t, size_t, solidfire::AllowReadTruncation)", "throwLine": 272, "whatString": "/dev/sd<ID>: Input/output error", "exceptionCode": "xFileReadFailed", "currentStack": "", "streamDetails": 1 }
{ "throwFile": "serviceshared/DiskDataDiskModel.cpp", "throwFunction": "solidfire::DiskFileScanner::LoadFileInfo()::<lambda(solidfire::FileNumber)>::<lambda()>", "throwLine": 204, "whatString": "IO Error reading segment header errno=5 result=0", "exceptionCode": "xSegmentHeaderReadIOError", "currentStack": "", "streamDetails": 1 }
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
