Common questions about SolidFire Element OS upgrade
Applies to
NetApp Element software 10.3 and above
Answer
- The following errors due to the known issues exist in the cluster, are these errors impacting the
sfinall
or health check?
Example:
Error Code Details
nodeHardwareFault Chassis component "Memory" reports status as "Critical".
nodeHardwareFault NVRAM device warning={fanInletAmbientTemperature: 56.67 C}
- These
nodeHardwareFault
not reports in the health check since it checks cluster faults in the cluster. - It also not impact
sfinstall
upgrade command. - Besides, use the
-f
option insfinstall
command can bypass the ignorable cluster faults if necessary.
- Are the connections via MVIP will be cut off while the last node (cluster master) being upgraded?
- The cluster master role is going to demote to another node while it is upgrading, so the connections on this node are also redirected to the new cluster master node.
- During the node upgrading, if SSD failure or node failure occurring on other nodes, how is the cluster capacity changing?
- It will no change during the BS Kill Timer(default is 1hr 15min) which is set by the upgrade command.
- For any node or SSD failure during the upgrade, and if the failed parts are holding the double-helix data with the upgrading node, is the recovery action only can be executed after the node upgrading?
- Yes.
- For the above scenario 4, what's the impact on the client?
- In most scenarios, the write operation is almost no impact but for the read operation which needs to access the failed parts will be impacted.
Additional Information
