NetApp Knowledge Base
Client has iSCSI connection failure with scsid: Login authentication failed
162
Visibility:
Votes:
0
Category:
element-software
Specialty:
hci
Last Updated:
Applies to
Element OS
Issue
Client fails to access volume after client and volume connection failure repetition
sf-slice.info log recurringly recorded:
./sf-slice.info.5:2020-XX-XXT10:35:41.602649Z node10 sliceXXX[31936]: [ISCSI] 2109 TSSocket-185 iscsitarget/ISCSISession.cpp:391:~ISCSISession|srcid=1634 reqid=0 Destroyed { sessionID=794568951394 cid=0 sessionMSec=6584574325 loginMSec=6 initiatorName=iqn.XXXX-XX.com.redhat:XXXX initiatorPortal=XXX.XXX.XXX.XXX:58336 isid=9613345279 sessionType=Normal targetName=iqn.XXXX-XX.com.solidfire:XXXX.XXXXX-XXXX-XXX-XXXX-XXXX-XXXX.XXXX targetPortal=XXX.XXX.XXX.XXX:3260 initiatorAccess=AllowedByAccount receivedCommands=160128416 shutdownReason=IscsiSocketError shutdownInfo=Destroyed isShutdown=true redirect=false virtualNetworkID=0 activeCommands=0 volumeID=XXXXX chapUsername=XXXX-XXXX chapAccountID=193 socketError=xSocketReadFailed at bool solidfire::Socket::PerformRead(int) (shared/Socket.cpp:1304): Connection reset by peer
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
