NetApp Knowledge Base
Client has iSCSI connection failure with scsid: Login authentication failed
395
Visibility:
Votes:
0
Category:
element-software
Specialty:
hci
Last Updated:
Applies to
Element OS
Issue
Client fails to access volume after client and volume connection failure repetition
sf-slice.info log recurringly recorded:
./sf-slice.info.5:2020-XX-XXT10:35:41.602649Z node10 sliceXXX[31936]: [ISCSI] 2109 TSSocket-185 iscsitarget/ISCSISession.cpp:391:~ISCSISession|srcid=1634 reqid=0 Destroyed { sessionID=794568951394 cid=0 sessionMSec=6584574325 loginMSec=6 initiatorName=iqn.XXXX-XX.com.redhat:XXXX initiatorPortal=XXX.XXX.XXX.XXX:58336 isid=9613345279 sessionType=Normal targetName=iqn.XXXX-XX.com.solidfire:XXXX.XXXXX-XXXX-XXX-XXXX-XXXX-XXXX.XXXX targetPortal=XXX.XXX.XXX.XXX:3260 initiatorAccess=AllowedByAccount receivedCommands=160128416 shutdownReason=IscsiSocketError shutdownInfo=Destroyed isShutdown=true redirect=false virtualNetworkID=0 activeCommands=0 volumeID=XXXXX chapUsername=XXXX-XXXX chapAccountID=193 socketError=xSocketReadFailed at bool solidfire::Socket::PerformRead(int) (shared/Socket.cpp:1304): Connection reset by peer
New to NetApp?
