Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
AutoSupport Message: Sensor Reading Failed on Element storage nodes
1,349
Visibility:
Votes:
2
Category:
element-software
Specialty:
solidfire
Last Updated:
Applies to
NetApp storage clusters running Element Software
  • NetApp SolidFire
  • NetApp HCI
Issue
Various sensor-related alerts can be generated on Element storage nodes as a result of issues with the node's underlying Baseboard Management Controller (BMC) and/or the internal hardware components (fans, power supplies, etc) that the BMC manages.
These include:
Error Code Error Details Node Component
fanSensor
FanXX RPM is failed or missing
Chassis Fans
sensorReadingFailed
sensorReadingFailed: IPMI diagnostics are currently unresponsive. Please contact support if this problem persists.
BMC
tempSensor
Error checking sensor for Exhaust Temp
Error checking sensor for Inlet Temp
Temperature Sensors
nodeHardwareFault
Error checking sensor for Fan<#> RPM
Fan RPM Sensors
nodeHardwareFault
BMC Self Test failed. This may impact IPMI based services and a BIOS/BMC update may be recommended
BMC
nodeHardwareFault
BMC
The associated impacts of the various sensor alerts range from none (false positive alerts at particular Element versions and node types) to impacting node an cluster performance.
Use this article to determine and pursue the troubleshooting path for the particular collection of alerts on the cluster in question.
New to NetApp?
Scan to view the article on your device
