NetApp Knowledge Base
"Key size" error when setting a custom SSL certificate in Element Software
47
Visibility:
Votes:
0
Category:
element-software
Specialty:
solidfire
Last Updated:
Applies to
  • Element Software version 12.0 and above
  • Element Management Node (mNode) version 12.0 and above
Issue
When attempting to install a custom SSL Certificate on an Element cluster or Element mNode using the SetSSLCertificate (cluster) or SetNodeSSLCertificate (mNode) API methods, the operation fails with the following error:
"Key size [submitted_key_length] should be a minimum of 2048 bit for RSA"
For instance:
Key size [1024] should be a minimum of 2048 bit for RSA when attempting to apply a key of bit length 1024.
Full example:
"error": {
"code": 500,
"message": "Key size [1024] should be a minimum of 2048 bit for RSA",
"name": "xInvalidCertificate"
"id": null
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
