NetApp Element Plug-In for vCenter Server (VCP) is not visible in vSphere 7.0 U1
- 587
- Visibility:
- Public
- Votes:
- 0
- Category:
- element-plug-in-for-vcenter-server
- Specialty:
- solidfire
- Last Updated:
Applies to
- NetApp Element Plug-In for VMware vCenter Server (VCP) 4.4 and below
- VMware vSphere 7.0 Update 1
Issue
After installing or upgrading to vCenter 7.0 Update 1 and subsequently registering the NetApp Element plug-in for vCenter (VCP) 4.4, the plug-in components does not appear in the vSphere web client.
Error reported:
org.apache.felix.resolver.reason.ReasonException: Unable to resolve /etc/vmware/vsphere-ui/vc-packages/vsphere-client-serenity/com.solidfire-4.4.0.0/com.solidfire-4.4.0.0.esa/com.springsource.org.dom4j-1.6.1.jar: missing requirement org.apache.aries.subsystem.core.archive.ImportPackageRequirement: namespace=osgi.wiring.package, attributes={}, directives={filter=(&(osgi.wiring.package=javax.xml.stream.util)(&(version>=1.0.1)(!(version>=2.0.0)))), resolution=mandatory}, resource=/etc/vmware/vsphere-ui/vc-packages/vsphere-client-serenity/com.solidfire-4.4.0.0/com.solidfire-4.4.0.0.esa/com.springsource.org.dom4j-1.6.1.jar org.apache.felix.resolver.Candidates$MissingRequirementError.toException(Candidates.java:1340) org.apache.felix.resolver.Candidates$MissingRequirementError.toException(Candidates.java:1341) org.apache.felix.resolver.ResolverImpl.doResolve(ResolverImpl.java:433) org.apache.felix.resolver.ResolverImpl.resolve(ResolverImpl.java:420) org.apache.felix.resolver.ResolverImpl.resolve(ResolverImpl.java:413) org.apache.aries.subsystem.core.internal.SubsystemResource.computeDependencies(SubsystemResource.java:393) org.apache.aries.subsystem.core.internal.SubsystemResource.computeDependencies(SubsystemResource.java:363) org.apache.aries.subsystem.core.internal.SubsystemResource.<init>(SubsystemResource.java:101) org.apache.aries.subsystem.core.internal.SubsystemResource.<init>(SubsystemResource.java:91) org.apache.aries.subsystem.core.internal.InstallAction.run(InstallAction.java:60) org.apache.aries.subsystem.core.internal.InstallAction.run(InstallAction.java:27) java.security.AccessController.doPrivileged(Native Method) org.apache.aries.subsystem.core.internal.BasicSubsystem.install(BasicSubsystem.java:677) org.apache.aries.subsystem.core.internal.BasicSubsystem.install(BasicSubsystem.java:730) org.apache.aries.subsystem.core.internal.BasicSubsystem.install(BasicSubsystem.java:304) org.apache.aries.subsystem.core.internal.BasicSubsystem.install(BasicSubsystem.java:299) org.apache.aries.subsystem.core.internal.BasicSubsystem.install(BasicSubsystem.java:71) com.vmware.vise.extensionfw.impl.OsgiBundleDeployer$SubsystemInstallerTask.run(OsgiBundleDeployer.java:624) java.lang.Thread.run(Thread.java:748)
