How to retrieve a core dump on an E-Series storage system
Applies to
E-Series Controller Firmware 7.xx
E-Series Controller Firmware 8.xx
Caution: Perform this procedure only under the guidance of NetApp Support. |
Note: Core dump operations can only be performed on E5400, E2700, E5500, E2800, E5700 and higher Controller models.
Retrieve a core dump under the following conditions:
If you receive notification of a major event log "MEL" event that a core dump has been automatically generated.
If you generate a core dump manually.
