NetApp Knowledge Base
ARVM with large volumes can cause a controller reset
250
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
  • E-series Controller firmware 8.25 or higher
  • E5500
  • E5600
Issue
These are the common errors seen with this defect:
  • Page fault at vutl::PagePool::findAllocatedPage
  • ASSERT: Assertion failed: node != NULL, file vutlPagePool.cc, line 173
  • Mirror has >7TB capacity and failed with reason MEL_RC_FAIL_DL_L1BLOCK_READ_ERROR in MEL's raw data
  • Size mismatch with next memory block vkiHdr=0xffff800035ddb6e0
The defect can have many different types of unexpected rebooted with stack traces that often make no sense as a result of the memory corruption.
New to NetApp?
