Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
HANA backups fail during DB quiesce/unquiesce operations with "error SCF-00037 Application quiesce for plug-in hana failed with error and exit code1 Exiting"
320
Visibility:
Votes:
0
Category:
snap-creator-framework
Specialty:
snapx
Last Updated:
Applies to
Snap Creator 4.3 and newer
Issue
Backup jobs for HANA DBs are failing either during HANA DB quiesce or unquiesce operations.
During the quiesce of the database the following error messages will be seen:
  • ERROR: [hostname:9090 (4.3.0.0)] Quiesce failed with error
  • ERROR: [hostname:9090(4.3.0.0)] SCF-00037: Application quiesce for plug-in [hana] failed with error [] and exit code [1], Exiting!
During the unquiesce of the database the following error messages will be seen:
  • ERROR: [hostname:9090 (4.3.0.0)] Another unquiesce operation is already running on this profile/config
  • ERROR: [hostname:9090(4.3.0.0)] SCF-00032: Application unquiesce failed due to application error.
New to NetApp?
Scan to view the article on your device
