SnapManager does not update SnapMirror XDP
- 266
- Visibility:
- Public
- Votes:
- 3
- Category:
- snapmanager-for-microsoft-sql-server
- Specialty:
- dp
- Last Updated:
Applies to
- SMHV 2.1
- SME 7.X
- SMSQL 7.x
Issue
- SnapManager for Hyper-V, Exchange, or SQL might not correctly be able to create snapshots with a SnapMirror label and they might not show the
Archive Backup
option in theBackup and Verify
option. - No SnapVault (Native SnapMirror XDP) update is done on any of the volumes containing LUNs or CSVs.
- No SnapMirror XDP update is possible for the SnapInfo volume either.
The above symptom manifests itself even though the local backups are working fine and the SnapMirror policy on the destination is configured correctly, according to the following article:
SnapManager integration setup attempts with SnapMirror XDP results in SnapManager showing the archive backup to secondary storage checkbox as disabled
