NetApp Knowledge Base
SnapDrive fails to run a snapshot with 5 minute timeout or lock file error
163
Visibility:
Votes:
0
Category:
snapdrive-for-unix
Specialty:
snapx
Last Updated:
Applies to
  • SnapDrive for Unix (SDU)
  • SnapManager for Oracle (SMO)
  • SnapManager for SAP (SMSAP)
Issue
SnapDrive fails to create a snapshot with the following error found inside the sd-trace.log.# trace file:
Operation::addErrorReport: (1) FilerVolume:<STORAGE_IP>:/vol/<VOLUME> 220012 8501:Could not acquire lock file on storage system - more than one instance of snapdrive may be trying to create snapshots.
If no other instance is trying to create a snapshot (even on other hosts),
please delete file /vol/<VOLUME>/.snapdrive_lock on storage system <STORAGE_IP> and retry.
To delete the file, mount the volume <VOLUME> using junction path
and execute the command
'rm $mount_pt/.snapdrive_lock' on host.
Since SDU takes more than 7 minutes to fail that way, in the SMO or SMSAP report, you would see the following instead:
[ERROR]: EXE-00002: Timeout of 0:05:00.000 occurred while executing command: /usr/sbin/snapdrive snap create -fs /<ORA_MOUNT_POINT> -snapname <smo|smsap>_<SID>_h_<DATE>_<TIME>_1_UUID_0 -unrelated
[DEBUG]: SD-00003: Error creating snapshot: EXE-00002: Timeout of 0:05:00.000 occurred while executing command: /usr/sbin/snapdrive snap create -fs /<ORA_MOUNT_POINT> -snapname <smo|smsap>_<SID>_h_<DATE>_<TIME>_1_UUID_0 -unrelated
following by a java ProcessExecutionException trace. However, extending the timeout for SDU will show the first error.
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
