SMSQL backup failing with an error "Remote backup failed with Exception, Error code: 0x80131501"
- 332
- Visibility:
- Public
- Votes:
- 0
- Category:
- snapmanager-for-microsoft-sql-server
- Specialty:
- snapx
- Last Updated:
Applies to
- SnapManager for SQL (SMSQL)
- Microsoft SQL Server
Issue
- SnapManager for SQL backup failing with errors:
[...] Maximum worker threads setting for [<server_name\server_instance>] = 1280
[...] Current worker threads number for [<server_name\server_instance>] = 1982
[...] The number of databases selected for concurrent backup exceeds the maximum number of SQL Server worker threads that are available on the SQL Server <server_name\server_instance> to perform this backup.
[...] specify 'Modify SQLServer maximum worker threads parameter' option to increase the maximum worker threads for the SQL Server <server_name\server_instance>.
[...] Remote backup failed with Exception, Error code: 0x80131501
