Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
SMHV does not delete snapshots when dataset contains more then 2 volumes
110
Visibility:
Votes:
0
Category:
snapmanager-for-hyper-v
Specialty:
snapx
Last Updated:
Applies to
SnapManager for Hyper-V (SMHV) 2.1.4P1/P2
Issue
  • SMHV is not removing snapshots per retention
  • Backup taking a long time to run
  • Successfully enumerating snapshots, but failing with the error seen in the SMHV job report:
An error occurred while deleting snapshot. continuing with rest of the snapshots(if any)
An item with the same key has already been added.Source: mscorlib
Stack Trace:    at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource)
   at System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)
   at NetApp.SnapManager.RetentionPolicyHandler.DeleteSnaps(SmSnapList lstSnaps, Dictionary`2& IsMetaDataDelete)
New to NetApp?
Scan to view the article on your device
