The NetApp Knowledge Base Site will be down for 60 minutes on August 13, 2022, from 8 PM to 9 PM PT for system maintenance and infrastructure update.
SMHV backup fails by "Writer returned failure code 0x0. Writer state is 1."
121
Visibility:
Votes:
0
Category:
snapmanager-for-hyper-v
Specialty:
snapx
Last Updated:
Applies to
SnapManager for Hyper-V (SMHV) 2.1.2
Issue
  • SMHV backup fails by "Writer returned failure code 0x0. Writer state is 1."
Sending backup complete notification to VSS writers
Saving VSS backup metadata
Writer "Microsoft Hyper-V VSS Writer" involved in backup or restore operation reported partial failure. Writer returned failure code 0x0. Writer state is 1.
Application specific error information:
Application error code: 0x0
Application error message: -
Failed component information:
For more information, look at the Hyper-V-VMMS event log in the Windows Event Viewer under "Applications and Services Logs->Microsoft->Windows".Also, check the Windows application event log in the VM for any errors.
  • Application event log shows error.
ERROR,<HOST>,SnapMgrServiceHost,106,"SnapManager for Hyper-V backup failed to complete
Backup of the Dataset Name: <DATASET>
Backup id: <ID> failed to execute
 Error :Error: Vss Requestor - Backup Components failed with partial writer error.Writer 'Microsoft Hyper-V VSS Writer' involved in backup or restore operation reported partial failure. Writer returned failure code 0x0. Writer state is 1.
For more information, look at the Hyper-V-VMMS event log in the Windows Event Viewer under 'Applications and Services Logs->Microsoft->Windows'.Also, check the Windows application event log in the VM for any errors.
  • Hyper-V-VMMS event log shows error.
    • Could not create backup checkpoint for virtual machine <VIRTUAL MACHINE>: The writer's timeout expired between the Freeze and Thaw events. (VSS error 0x800423F2). (Virtual machine ID <ID>)
    • VSS writers inside virtual machine '<VIRTUAL MACHINE>:' failed to perform BackupComplete to its shadow copy (VSS snapshot) set: Catastrophic failure (0x8000FFFF). (Virtual machine ID <ID>)
    • VSS writers inside virtual machine '<VIRTUAL MACHINE>:' failed to perform BackupComplete to its shadow copy (VSS snapshot) set: A function call was made when the object was in an incorrect state for that function (0x80042301). (Virtual machine ID <ID>)
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
