NetApp Knowledge Base
Snapdrive for Windows fails to mount a RDM LUN in vSphere 6.5 due to a 1024 path limitation - Failed to Add the virtual Disk through raw device mapping
297
Visibility:
Votes:
0
Category:
snapdrive-for-windows
Specialty:
legacy
Last Updated:
Applies to
Snapdrive for Windows 7.1.4/7.1.5
VMware vSphere 6.5
Issue
Attempts to mount a RDM LUN using Snapdrive for Windows fails, generating an error
Failed to create disk in virtual machine, Failed to Map virtual disk: The ESX cannot have more than 1024 paths.
Review of the Snapdrive debug logs shows entires similar to the following:
05/08-14:55:46.815    PID:7184    TID:2232    FCPVdisk.cpp@4121        Failed to Add the virtual Disk through raw device mapping, , error code: '0x80004005', error description: 'Failed to Map virtual disk: The ESX cannot have more than 1024 paths'
05/08-14:55:46.815    PID:7184    TID:2232    FCPVdisk.cpp@4123        Failed to create disk in virtual machine, Failed to Map virtual disk: The ESX cannot have more than 1024 paths.
 HRESULT 0xc00403e3.
Review of the VirtualizationAPI log shows entries similar to the following:
VirtualizationAPILog Critical: 1 :    05/08-15:02:33.190  PID:9516  TID:8728 @-1  CEsxServer::GetLunInformation()  Name : COMException Message : The ESX cannot have more than 1024 paths Trace :    at VirtualizationAPI.CEsxServer.GetLunInformation(String strLunSerialNo, UInt32 nLunId, String& strDeviceName, String& strLUNuuid, EnumAdapterType eAdapterType, String strInitiatorName)
VirtualizationAPILog Critical: 1 :    05/08-15:02:33.190  PID:9516  TID:8728 @-1  CEsxServer::MapVirtualDisk() -  Name : COMException Message : The ESX cannot have more than 1024 paths Trace :    at VirtualizationAPI.CEsxServer.GetLunInformation(String strLunSerialNo, UInt32 nLunId, String& strDeviceName, String& strLUNuuid, EnumAdapterType eAdapterType, String strInitiatorName)
   at VirtualizationAPI.CEsxServer.MapVirtualDisk(String strLunSerialNo, UInt32 nLunId, String strDataStoreName, String strFilerName, UInt64 nSizeInKB, Boolean bRDMFileSpecified, String strRDMFileName, Boolean bShared, EnumAdapterType eAdapterType, String strInitiatorName, UInt32& nControllerKey)Datastore :<DS ID>
Review of the Window's Application Event logs show entries similar to the following:
Event ID 1120
The following information was included with the event:
/vol/volumename/
HTTPS
X
X
Failure in connecting to the LUN
New to NetApp?
