NetApp Knowledge Base
SnapDrive for Unix fails to mount a lun for an AIX cluster
113
Visibility:
Votes:
2
Category:
snapdrive-for-unix
Specialty:
legacy
Last Updated:
Applies to
  • SnapDrive for Unix
  • AIX Cluster
Issue
SnapDrive for Unix fails to mount a lun for an AIX cluster when using the snapdrive snap connect command and fails with the error
0001-199 Command error: Snapdrive could not import /dev/vg_NTAPPRD01_bin: Device not found in CuDv class while setting ODM attribute
From the SDU logs we see the error
11-01-2021 12:38:24 [51839118 1a3]v,9,0,ASSISTANT EXECUTION (at 1219966.850853): Output:
vg_NTAPPRD01_bin
0516-1972 varyonvg: The volume group is varied on in other node in concurrent
mode; you cannot vary on the volume group in non-concurrent mode. Use -O
flag to force varyon the volume group if needed.
New to NetApp?
