NetApp Knowledge Base
System Manager login fails with with http error
199
Visibility:
Votes:
0
Category:
oncommand-system-manager
Specialty:
om
Last Updated:
Applies to
  • ONTAP 9
  • OnCommand System Manager (integrated)
Issue
  • cannot access System Manager UI
  • can't login in OnCommand System Manger
  • when enabling http you can get logs from SPI
  • since we have a http forwarding to https on the UI it cannot work that way on System Manager UI
  • The issue is clearly that ssl is not working
  • in the apache logs we find:
[Wed Dec 02 23:04:36.671053 2020  0000] [ssl:notice] [pid 66541:tid 34376558080] [client 10.10.10.10:36372] [vserver 4294967295] No server certificate chain is configured for this vserver
[Wed Dec 02 23:04:36.671805 2020  0000] [ssl:notice] [pid 66541:tid 34376558080] [client 10.10.10.10:36372] [vserver 4294967295] Certificate-based client authentication is not configured for this vserver
[Wed Dec 02 23:04:36.697214 2020  0000] [ssl:emerg] [pid 66541:tid 34376558080] AH02562: Failed to configure certificate 127.0.0.1:0 (with chain), check /mroot/etc/vserver_4294967295/certificates/ssl/server/20 05B31FE6DD6C66 cluster02/server.crt
[Wed Dec 02 23:04:36.697243 2020  0000] [ssl:emerg] [pid 66541:tid 34376558080] SSL Library Error: error:0E079065:configuration file routines:DEF_LOAD_BIO:missing equal sign (line 17)
[Wed Dec 02 23:04:36.697252 2020  0000] [ssl:error] [pid 66541:tid 34376558080] [client 10.10.10.10:36372] [vserver 4294967295] Failed to initialize SSL context
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
