Modification of volume attributes failed on volume which is part of application
Applies to
- ONTAP 9.x (all versions)
- ONTAP System Manager (Onbox)
Issue
When attempting to modify parameters for volumes provisioned by "Application" (OCSM Dashboard > Applications & Tiesrs > Applications) the operation will fail with error:
Error: command failed: Modification of volume attributes failed on volume "
" which is part of application "
" in Vserver "
". The Snapshot policy cannot be modified on volumes which are part of an application.
