NetApp Knowledge Base
OnCommand Insight Data Warehouse 7.3.3 through 7.3.9, installation fails at "Starting Reporting Engine" step, with error "There is a problem with this Windows Installer package"
229
Visibility:
Votes:
0
Category:
oncommand-insight-data-warehouse
Specialty:
oci
Last Updated:
Applies to
OnCommand Insight Data Warehouse (DWH) 7.3.3 - 7.3.9 (Windows Installations)
Issue
When installing DWH for Windows, the install process gets stuck at the "Starting Reporting Engine" step. After some time the installation fails with an error:
There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor.
Using Windows Event Viewer to review the Security Event logs reveals an error with Security Event ID 4625. This is an authentication error that reports "Failure Reason: The user has not been granted the requested logon type at this machine."
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
