NetApp Knowledge Base
Why do Aggregate statistics change per volume in OnCommand Unified Manager Core file system level reports?
46
Visibility:
Votes:
0
Category:
oncommand-unified-manager
Specialty:
om
Last Updated:
Applies to
Answer
  • When using the Aggregate base catalog and Aggregates display tab for a report the value displayed for the Aggregate Total Space column is the actual total space for the aggregate
  • Similarly the Aggregate Used Capacity column shows the total of all the used space in the aggregate the meaning of the value in these columns changes
  • However, when using the Volume base catalog and File Systems the meaning of the value in these columns changes
  • In this view the Aggregate Used Capacity column shows the amount of space within the aggregate the volume is using
  • The Aggregate Used Capacity shows the amount of space the data in the volume is using in that aggregate
Additional Information
