NetApp Knowledge Base
What is the difference between Active IQ Digital Advisor and Active IQ Unified Manager?
2,696
Visibility:
Votes:
1
Category:
oncommand-unified-manager
Specialty:
om
Last Updated:
Applies to
  • Active IQ Unified Manager(AIQUM) 9.6+
  • Active IQ Digital Advisor(AIQDA)
Answer
Active IQ and Active IQ Unified Manager are not the same products.
  • Active IQ is Web based and only visible on http://activeiq.netapp.com/ and this is regarding your active configurations. It gives an overview of ONTAP clusters, SolidfFire, StorageGRID, etc..
  • update interval is the same as automatic support logs (ASUP), means one time a day and for some configuration data weekly
  • For more information, see Active IQ Digital Advisor on the NetApp site
  • If there is any issues with Active IQ  open a ticket via the NOW site.
  • ActiveIQ Unified Manager is a monitoring suite you can install locally. It is available as an application for Windows and RHEL and as a virtual appliance within VMWare.
  • update interval of inventory data is every 15 min system defined and for performance data 5-15 min per setting
  • Prior to ActiveIQ Unified Manager 9.6, the product was known as OnCommand Unified Manager.
  • For general information on NetApp Web page, see ONTAP: The industry-leading enterprise data management software
  • For more information, see Active IQ Unified Manager Support.
  • If you are experiencing issues with the monitoring software, open a case with Technical Support.
Additional Information
additionalInformation_text
Scan to view the article on your device
