Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
What disks are in use with the Active IQ Unified Manager Virtual Appliance
462
Visibility:
Votes:
2
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
  • OnCommand Unified Manager 7.x, 9.x (UM)
  • Active IQ Unified Manager 9.x (UM)
Answer
By default, the UM Virtual Appliance (vApp) has 4 virtual drives
  • Disk 1: Rootfs (By default 60GB)
  • Disk 2: Swap (By default 12GB)
  • Disk 3: Data (By default 50GB)
  • Disk 4: Jail drive (By default 30GB)
Disk 1 contains the root filesystem which is the top-level directory of the filesystem in which other filesystems mount to. It also contains the files necessary to boot the Debian Linux kernel as well as UM log files
Disk 2 is the space used for virtual memory extension
Disk 3 primarily contains the database and the UM database backup files
Disk 4 is primarily used to store Support Bundles
Additional Information
  • You can only extend the swap drive (Disk 2) and the data drive (Disk 3). If you plan to use the Unified Manager backup and restore feature, allocate additional capacity so that the data directory or disk has 150 GB of space
Scan to view the article on your device
