What are HTTP status codes in Active IQ Unified Manager?
Applies to
- OnCommand Unified Manager (OCUM)
- Active IQ Unified Manager (AIQUM)
Answer
- When you load the Unified Manager web page, the Unified Manager server will return the most appropriate HTTP status codes as defined in the HTTP/1.1 standards.
- You might receive one of the following HTTP codes:
- 200 OK
- 400 Bad Request
- 401 Unauthorized
- 403 Forbidden
- 404 Not Found
- 500 Internal Server Error
- 503 Service Unavailable.
- In the following table you can find a short explanation of each HTTP code and its meaning for the Unified Manager server.
Status Code | Description |
200 OK | Returned in response to all successful API requests on the URIs exposed by Unified Manager. The representations of the requested resource(s) are in the response body. |
400 Bad Request | Unified Manager could not interpret the request, also applies to REST APIs. |
401 Unauthorized | The Unified Manager request did not contain a valid authorization token. |
403 Forbidden | User is not authorized to access the resource or execute the method on the resource. Typically happens when Unified Manager user does not have necessary roles. |
404 Not Found | The requested resource is not available on the Unified Manager Server. For storage resources this may happen if the configuration data cache is not yet refreshed from the storage system. |
500 Internal Server Error | The Unified Manager server experienced and internal error when processing the request. E.g. database service is not available or there is a communication error when accessing one of the internal services like "ocum" or "ocie" etc. |
503 Service Unavailable | Indicates the Unified Manager server is overloaded with requests. |
Additional Information
additionalInformation_text
