WFA - Acquisition stopped working after installing SVM-DR Pack
- 152
- Visibility:
- Public
- Votes:
- 0
- Category:
- oncommand-workflow-automation-wfa
- Specialty:
- om
- Last Updated:
Applies to
- OnCommand Unified Manager
- OnCommand Workflow Automation
- Storage Virtual Machine Disaster Recovery pack
Issue
After installing the Storage Virtual Machine Disaster Recovery Pack from the automationstore.netapp.com
acquisition is failing on the Unified Manager Datasource.
In the wfa_acquisition.log
the error is shown :
2020-02-01 02:18:11,997 ERROR [com.netapp.wfa.cache.job.CacheJobExecutorImpl] (Thread-9924 (HornetQ-client-global-threads-328303623)) Failed running cache job - databases were dumped to D:\Program Files\NetApp\WFA\jboss\standalone\tmp\wfa\localhost-wfa_staging#cm_storage-5344397166306204663.dump: com.netapp.wfa.util.SqlShellException: Failed to get description of table 'cm_storage.svmdr_volume_attributes'
Caused by: java.sql.SQLSyntaxErrorException: Table 'cm_storage.svmdr_volume_attributes' doesn't exist
Caused by: org.mariadb.jdbc.internal.common.QueryException: Table 'cm_storage.svmdr_volume_attributes' doesn't exist
