NetApp Knowledge Base
WFA OCUM datasource error"not allowed to connect to this MySQL server"
17
Visibility:
Votes:
0
Category:
oncommand-workflow-automation-wfa
Specialty:
om
Last Updated:
Applies to
Oncommand Workflow Automation (WFA) 5.1
Oncommand Unified Manager (OCUM) 9.5P1
Issue
WFA OCUM datasource status fails with error.
The error in WFA log is as follows,
2021-05-27 06:53:40,282 ERROR [com.netapp.wfa.job.backend.JobsExecutionInterceptor] (Thread-9892 (ActiveMQ-client-global-threads)) Job CacheJob{, dataSourceId=DataSourceInfo{id=44, name='UM 9.5 : FQDN.com', connectionDetails=ConnectionDetails{id=70, ip='FQDN', port=3306, userName='wfauser', password='******', databaseName='null', timeoutInMinutes=10, lastUpdateTime=0}, dataProviderType=DataProviderType{id=16, productType='OnCommand Unified Manager', productVersion='9.5', scheme='cm_storage'}}, schemeId=Scheme{id=4, name='cm_storage'}, dataSourceName='UM 9.5 : FQDN.com', schemeName='cm_storage'} failed: javax.ejb.EJBException: com.netapp.wfa.util.SqlShellException: Failed to get connection from data-source
Caused by: com.netapp.wfa.util.SqlShellException: Failed to get connection from data-source
Caused by: java.sql.SQLException: Host 'FQDN.com' is not allowed to connect to this MySQL server
at org.mariadb.jdbc//org.mariadb.jdbc.internal.com.read.ReadInitialHandShakePacket.(ReadInitialHandShakePacket.java:91)
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
