NetApp Knowledge Base
WFA 5.1 Command box empty once running a big workflow
48
Visibility:
Votes:
0
Category:
oncommand-workflow-automation-wfa
Specialty:
om
Last Updated:
Applies to
  • OnCommand Workflow Automation  5.1 Ga
Issue
  • In execution status portal, when a large workflow is running, with more than about 20 commands, the command logs are no longer visible for the latter commands i.e. when you click the (i) icon on the green command box the command logs are empty
  • It is possible to download the logs though at the end using the download log button
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
