Unable to access System Manager and disable SAML through SP in AWS CVO
Applies to
- Cloud Volumes ONTAP (CVO) 9.7RC1
- ONTAP System Manger
- AWS
Issue
When attempting to disable SAML over system console via the Service Processor (SP) for an AWS CVO setup, SAML modify commands fail.
aws_node_01::> security saml-sp modify -is-enabled false
Error: command failed: SAML authentication can only be disabled from the "console" application or from a SAML authenticated application.
