Troubleshooting WFA installation issues
- 616
- Visibility:
- Public
- Votes:
- 2
- Category:
- oncommand-workflow-automation-wfa
- Specialty:
- legacy
- Last Updated:
Applies to
Oncommand Workflow Automation 5.1
- The preferred method of upgrading OnCommand Workflow Automation (WFA) is to do an inline or in-place upgrade
- This article addresses common issues encountered when performing upgrades
Symptom |
Solution |
Could not take Backup of WFA database successfully. Aborting upgrade. | In-place upgrade of WFA fails while creating WFA database backup |
Could not verify schema validation | WFA Installation/Upgrade Failure - Could not verify schema validation |
Install or upgrade hangs when using a long password | OnCommand WFA hangs when using long password |
WFA upgrade does not contain correct installed packs | WFA upgrade does not copy correct installed packs |
Additional Information
For information on changing Workflow Automation Passwords, see How to change OnCommand Workflow Automation 5.1 user passwords
