NetApp Knowledge Base
The OnCommand DataWarehouse connector ETL process from the OnCommand Insight server does not complete
92
Visibility:
Votes:
0
Category:
oncommand-insight-data-warehouse
Specialty:
oci
Last Updated:
Applies to
  • OnCommand Insight (OCI) 7.3.x
  • OnCommand Insight DataWarehouse (DWH) 7.3.x
Issue
OnCommand DataWarehouse connector Extract Transfer Load (ETL) process from the OnCommand Insight server does not complete.
ETL Job status can reflect:
  • ABORTED
  • SKIPPED
  • FAILED
Below are some examples of errors that may be found in the \Sanscreen\wildfly\standalone\log\dwh.log :
  • Caused by: org .m ariadb.jdbc.internal.common.QueryException: Cannot add or update a child row: a foreign key constraint fails (`dwh_inventory_staging`.`storage_node_to_port`, CONSTRAINT `fk_storage_node_to_port_portId` FOREIGN KEY (`portId`) REFERENCES `dwh_inventory`.`storage_port` (`id`) ON DELETE CASCADE)
  • SequenceProcessor (SequenceProcessor.java:123) -dwh_inventory_staging.storage_pool_to_disk: Loading to public table completed (using connector'CONNECTOR_NAME') - 399248 rows added or modified
  • InventoryRunnerBean (InventoryRunnerBean.java:200) - Failed to dump databases after inventory job failure: com.netapp.sanscreen.dwh.util.SqlShellException: Failed to creat JDBC statement at com.netapp.sanscreen.dwh.util.SqlShell.createStatement(SqlShell.java:1339)
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
