NetApp Knowledge Base
Some storage systems within an OnCommand Insight HDS datasource stop reporting performance statistics
23
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
Applies to
OnCommand Insight 7.3.X (OCI)
Issue
  • For storage systems attached to a HiCommand Device Manager datasource, some are reporting performance stats and some do not
  • No errors are shown in the datasource in OCI
  • The API to report the performance stats returns an empty set, which can be confirmed with the following steps:
    1. Download and extract an error report from the datasource
    2. Open one of the numbered folders with the storage performance report: ErrorReportName\acq\storageperformance_<datasourcename>_656_2021_02_24_11_01_32_742\1614163099532
    3. Open the recording_storageperformance-<datasourcename>.dat and search for the storage with the missing stats
    4. The request will have the storage name, and the response will return a list of stat names and variable types, but no actual stat numbers
Missing stats example request and response:
<<< REQUEST >>>
GET http://<tuningManagerHostnameOrIP>:22015/TuningManager/v1/objects/RAID_PI_PRCS?hostName=<dataSourceName>&agentInstanceName=<storageName>&startTime=2021-02-24T10%3A35Z&endTime=2021-02-24T10%3A39Z HTTP/1.1
<<< REQUESTEND >>>
<<< RESPONSE >>>
HTTP/1.1 200 OK
Date: Wed, 24 Feb 2021 10:39:26 GMT
Server: Cosminexus HTTP Server
X-Frame-Options: SAMEORIGIN
Cache-Control: no-store, no-cache
X-Content-Type-Options: nosniff
Content-Security-Policy: frame-ancestors 'self'
Vary: Accept-Encoding
Last-Modified: Wed, 24 Feb 2021 10:39:26 GMT
X-XSS-Protection: 1; mode=block
Keep-Alive: timeout=5, max=21
Connection: Keep-Alive
Transfer-Encoding: chunked
Content-Type: text/csv;charset=utf-8
INPUT_RECORD_TYPE,DATETIME,GMT_ADJUST,RECORD_TIME,ADAPTOR_ID,PROCESSOR_ID,INTERVAL,CONTROLLER,PROCESSOR_TYPE,PROCESSOR_BUSY_RATE,MAX_PROCESSOR_BUSY_RATE,MAX_BUFFER_LENGTH,BUFFER_IO_COUNT,MAX_BUFFER_IO_COUNT,BUFFER_IO_RATE,MAX_BUFFER_IO_RATE
string(8),time_t,long,time_t,string(16),string(16),ulong,string(8),string(8),float,float,float,float,float,float,float
<<< RESPONSEEND >>>
Collecting stats example response (truncated):
<<< RESPONSE >>>
HTTP/1.1 200 OK
INPUT_RECORD_TYPE,DATETIME,GMT_ADJUST,RECORD_TIME,LDEV_COUNT,MONITORED_LDEV_COUNT,INTERVAL,READ_IO_COUNT,READ_IO_RATE,READ_HIT_IO_COUNT,READ_HIT_RATE,WRITE_IO_COUNT,WRITE_IO_RATE,WRITE_HIT_IO_COUNT,WRITE_HIT_RATE,READ_MBYTES,READ_XFER_RATE,WRITE_MBYTES,WRITE_XFER_RATE,READ_TOTAL_RESPONSE,READ_RESPONSE_RATE,WRITE_TOTAL_RESPONSE,WRITE_RESPONSE_RATE
string(8),time_t,long,time_t,ulong,ulong,ulong,double,double,double,double,double,double,double,double,double,double,double,double,double,double,double,double
"LDA",2021-02-24 10:35:00,0,2021-02-24 10:35:01,14,14,60,4.30000000000000E+01,7.16666666666667E-01,4.30000000000000E+01,1.00000000000000E+02,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,1.00000000000000E+00,1.66666666666667E-02,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00
"LDA",2021-02-24 10:36:00,0,2021-02-24 10:36:00,14,14,59,4.30000000000000E+01,7.28813559322034E-01,4.30000000000000E+01,1.00000000000000E+02,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,1.00000000000000E+00,1.69491525423729E-02,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00
"LDA",2021-02-24 10:37:00,0,2021-02-24 10:37:00,14,14,60,4.30000000000000E+01,7.16666666666667E-01,4.30000000000000E+01,1.00000000000000E+02,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,1.00000000000000E+00,1.66666666666667E-02,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00
"LDA",2021-02-24 10:38:00,0,2021-02-24 10:38:01,14,14,61,4.50000000000000E+01,7.37704918032787E-01,4.50000000000000E+01,1.00000000000000E+02,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,1.00000000000000E+00,1.63934426229508E-02,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00
"LDA",2021-02-24 10:39:00,0,2021-02-24 10:39:00,14,14,59,4.30000000000000E+01,7.28813559322034E-01,4.30000000000000E+01,1.00000000000000E+02,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,1.00000000000000E+00,1.69491525423729E-02,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00
<<< RESPONSEEND >>>
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
