Snapmirror release workflow fails with: Unable to connect to array
- 99
- Visibility:
- Public
- Votes:
- 3
- Category:
- oncommand-workflow-automation-wfa
- Specialty:
- legacy
- Last Updated:
Applies to
- OnCommand Workflow Automation 5.1P4 (WFA)
- ActiveIQ Unified Manager 9.x (UM)
- ONTAP 9
Issue
- Executing the canned workflow Snapmirror release against a cluster fails with error:
Unable to connect to array.
- The same can happen with other workflows too
- Error seen in
wfa.log
2022-07-01 07:50:35,098 INFO [com.netapp.wfa.command.execution.instance.impl.ExecutionInstanceDaoImpl] (default task-138) [Release SnapMirror] Error while connecting HTTPSin NaServer::verify_server_certificate: server certificate verification failed: unsupported certificate purpose
2022-07-01 07:50:35,319 INFO [com.netapp.wfa.rs.csrf.CSRFFilter] (default task-138) ServletRequest URL = https://localhost:443/rest/execution...3199f2cf4a/log
2022-07-01 07:50:35,319 INFO [com.netapp.wfa.rs.csrf.CSRFFilter] (default task-138) Request Header ntap_request_csrf_token = null
2022-07-01 07:50:35,319 INFO [com.netapp.wfa.rs.csrf.CSRFFilter] (default task-138) Request Header X-CSRF-TOKEN = null
