SANscreen: Which are the ports used by OnCommand Insight?
Applies to
OnCommand Insight
Answer
Port conflict causing issues with functionality of OnCommand Insight (OCI).
LOCAL ONLY indicates that a port will accept communication only from a source on the same machine.
Acquisition
- 9009 [TCP] LOCAL ONLY Acquisition JMX console
- 9010 [TCP] LOCAL ONLY Acquisition JMX console
- 12123 [TCP] LOCAL ONLY
- 162 - [UDP] SNMP traps (Not mandatory)
Server
- 80 [TCP] HTTP access
- 443 [TCP] Primarily Acquisition to server access
- 1097 [TCP] JNDI (naming) - lookup of components in the server
- 1098 [TCP] JNDI (naming) - lookup of components in the server
- 1099 [TCP] JBoss
- 4444 - [TCP] JMX
- 4445 - [TCP] JMX
- 8083 - [TCP] JBoss WebService SOAP
- 8086 - [TCP] SOAP Monitor Port
- 8090 - [TCP] JBossMQ
- 8092 - [TCP] JBossMQ
- 8093 - [TCP] JBossMQ
MySQL
- 3306 [TCP] Server to MySQL communication Acquisition (work in progress).
Note: Not all the ports are needed. Only the ports that relate to one of the data sources used in your system are required.
- 161 - [UDP] Sphereon, Cisco
- 162 - [UDP] Sphereon, Cisco
- 1521 - [TCP] ECC StorageScope
- 2001 - [TCP] Hitachi HiCommand & HP Command View
- 2707 - [TCP] SymAPI
- 6389 - [TCP] CLARiiON CLI
- 59520 - [TCP] SWAPI
- 59521 - [TCP] SWAPI
- 51510-51513 - [TCP] EFCM/ConnectrixManager
- 22, 80, 4092, or 8088 - [TCP] NetApp - Uses one of the following ports depending on configuration.
- 80, 443 - CommandView, VMware
- 2301, 12301, 2372 - HP EVA
- 5999 - IBM SVC SMI-S & 3PAR SMI-S
- 22 - IBM SVC CLI & 3PAR CLI
- 5988, 5989 - SUN SMI-S
3997 - Incipient
Note: Refer to the Support Matrix embedded in the code of OCI.
See the OnCommand Insight Installation and Administration Guide for the latest port requirements for your version of OCI.
Additional Information
additionalInformation_text
