OnCommand Workflow Automation install hangs when using a long password
- 200
- Visibility:
- Public
- Votes:
- 0
- Category:
- oncommand-workflow-automation-wfa
- Specialty:
- om
- Last Updated:
Applies to
- OnCommand Workflow Automation (WFA) 5.1
- Windows Server 2016 and other Supported Versions
Issue
- When the installation wizard prompts you for the WFA server service logon account, the password you provide is greater than 14 characters
- After filling out the proceeding information to start the install, it hangs and doesn't progress past the following screen
- While the installation is hung, open Windows File Explorer and type
%temp%
in the address bar field and hit Enter to open the current user's temp directory - Locate the MSIxxx.log file associated with the current WFA install
- Scroll to the bottom of the log file and confirm that no updates have been made past the following section
InstallShield 10:24:19: Invoking script function wfaServerService
Custom Install Log INFORMATION:
MySQL Exe path : C:\Program Files\MySQL\bin
MySQL Home : C:\Program Files\MySQL
Executable path for creating symlinks : cmd.exe
The value of Program and Params for creating link cmd=cmd.exe /c mklink /D "E:\NetApp\WFA\jboss\standalone\deployments\log.war" "E:\NetApp\WFA\jboss\standalone\log.war"
Successfully Created link using cmd=cmd.exe /c mklink /D "E:\NetApp\WFA\jboss\standalone\deployments\log.war" "E:\NetApp\WFA\jboss\standalone\log.war"
Custom Install Log ERROR:
Successfully created dir=E:\NetApp\WFA\jboss\standalone\log.war\jboss
The value of Program and Params for creating linkcmd.exe /c mklink /D "E:\NetApp\WFA\jboss\standalone\log" "E:\NetApp\WFA\jboss\standalone\log.war\jboss"
Successfully created link using cmd = cmd.exe /c mklink /D "E:\NetApp\WFA\jboss\standalone\log" "E:\NetApp\WFA\jboss\standalone\log.war\jboss"
The value of Program and Params for creating link /c mklink /D "E:\NetApp\WFA\jboss\standalone\deployments\help.war" "E:\NetApp\WFA\jboss\standalone\help.war"
Successfully executed : cmd.exe /c mklink /D "E:\NetApp\WFA\jboss\standalone\deployments\help.war" "E:\NetApp\WFA\jboss\standalone\help.war"
The command line for making link:cmd.exe /c mklink /D "E:\NetApp\WFA\jboss\standalone\workflow-help" "E:\NetApp\WFA\jboss\standalone\help.war\workflow"
Successfully created a link. cmd.exe /c mklink /D "E:\NetApp\WFA\jboss\standalone\workflow-help" "E:\NetApp\WFA\jboss\standalone\help.war\workflow"
