NetApp Knowledge Base
OnCommand Workflow Automation 5.1 datasource acquisition fails with error: "Errcode: 13- Permission denied"
330
Visibility:
Votes:
0
Category:
oncommand-workflow-automation-wfa
Specialty:
om
Last Updated:
Applies to
  • OnCommand Workflow Automation 5.1 ( WFA )
  • Active IQ Unified Manager 9.7P1 ( AIQUM )
  • Windows Server 2016
Issue
  • OnCommand Workflow Automation 5.1 does not complete data source acquisition and remains on "Failed" status.
  • A similar error message may be seen:
File '[Install Path]\NetApp\WFA\jboss\standalone\tmp\wfa\address=(host=server-ip)(port=3306) (type=master)-cm_storage.resource_pool-6489269104570928791.dump' not found (Errcode: 13 - Permission denied) Query is: LOAD DATA INFILE ''[Install Path]/NetApp/WFA/jboss/standalone/tmp/wfa/address=(host=server-ip)(port=3306)(type=master)- cm_storage.resource_pool-6489269104570928791.dump' INTO TABLE wfa_staging.cm_storage_resource_pool
New to NetApp?
Scan to view the article on your device
