NetApp Knowledge Base
OnCommand Unified Manager fails to purge "unified-manager.xxxxxx" binlogs
800
Visibility:
Votes:
0
Category:
oncommand-unified-manager
Specialty:
legacy
Last Updated:
Applies to
  • OnCommand Unified Manager 7.2 ( UM )
  • OnCommand Unified Manager 7.3 ( UM )
  • VMware Virtual Machine OVA
  • Microsoft Windows Server 2012
  • Microsoft Windows Server 2016
  • Microsoft Windows Server 2019
  • Red Hat 6.x
  • Red Hat 7.x
  • CentOS 7.x
Issue
After upgrading OnCommand Unified Manager, the available space in "/data" or your Windows install directory began to decrease abnormally fast over time. In the example below the "/data" filesystem is 93% used. This rapid usage increase in Unified Manager is precursored by a upgrade of Unified Manager 6.x to Unified Manager 7.x.
diag@ocum:~$ df -TH
Filesystem               Type      Size  Used Avail Use% Mounted on
rootfs                   rootfs     64G   14G   47G  23% /
udev                     devtmpfs   11M     0   11M   0% /dev
tmpfs                    tmpfs     1.3G  173k  1.3G   1% /run
/dev/sda1                ext3       64G   14G   47G  23% /
tmpfs                    tmpfs     5.3M     0  5.3M   0% /run/lock
tmpfs                    tmpfs     5.2G     0  5.2G   0% /run/shm
/dev/sdd1                ext3       32G  123M   30G   1% /jail
/dev/mapper/data--vg-lv2 ext4      793G  698G   55G  93% /data
While attempting to upgrade Unified Manager 7.x one might run into the following message saying that there is not enough free space. For example: Upgrading from Unified Manager 7.2P1 to Unified Manager 9.4.
Unable to perform operation due to available disk space limitations. Please add additional storage to this VM or contact technical support for assistance"
Note: There are other situations one might encounter this message.
New to NetApp?
