NetApp Knowledgebase
OnCommand Unified Manager cluster removal stuck with the description "Deletion in progress"
Applies to
OnCommand Unified Manager 9.5
Issue
Unable to delete cluster from OnCommand Unified Manager. Cluster removal process stuck displaying "Deletion in progress" in the "Description" field on the "Configuration/Cluster Data Sources" page.
Collecting a support bundle, or directly looking at collected log "ocumserver.log", will have the following entry:
ERROR [admin] [default task-5] [c.n.o.r.m.e.GlobalExceptionHandler] /rest/datasources/12 com.onaro.sanscreen.acquisition.sessions.AcquisitionUnitException [177-153]
Fail Stop report from Originator:12
Caused by: com.onaro.sanscreen.acquisition.sessions.AcquisitionUnitException: Fail Stop report from Originator:12
If the Cluster is already decomissioned or changed you might see another error because it does not even start acquisition.
Server_mega.log
2019-06-25 07:23:28,595 ERROR [ServerService Thread Pool -- 390] c.n.o.n.e.EmsZapiManager (EmsZapiManager.java:740) - Failed to call system-get-version -- : java.io.IOException: The host [cluster name] not be resolved
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
