NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
NetApp Knowledge Base
OCUM 5.x: HTTP/HTTPS communication fails with error due to incorrect HTTPS/TLS configuration on ONTAP
424
Visibility:
Votes:
0
Category:
oncommand-unified-manager-core-package
Specialty:
om
Last Updated:
Applies to
OnCommand Unified Manager (OCUM) 5.x
Issue
  • API calls over HTTP or HTTPS are failing to the controller or cluster with the following error.
No permission to use 'hostsequiv' authentication, must be root
  • Command dfm host diag <HOST_NAME> returns the following error.
XML (https port 80) No permission to use 'hostsequiv' authentication, must be root
XML (https port 443) No permission to use 'hostsequiv' authentication, must be root.
  • Protection Manager job fails with the message including the followings.
    • Could not get live vol usage from filer for ..
    • Using data from the database instead ..
    • Failed to create secondary snapshot on ..
    • Unable to get a list of snapshots from the volume ..
New to NetApp?
Scan to view the article on your device
