We are redesigning the NetApp Knowledge Base site to make it easier to use and navigate. The new and improved site will be available the first week of October. Check out our video or read this KB article to know more about changes you’ll see on the site.
OnCommand Insight fails to restore performance archives
69
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
Applies to
  • OnCommand Insight 7.3.9 (OCI)
  • Windows
Issue
  • Within the OCI web interface, under Admin > Troubleshooting > Load Performance Archive,  the following error is seen:
PerformanceArchiverBean (http://PerformanceArchiverBean.java:956) - Failed to load archive for date: >>Wed Jan 22 18:22:44 CET 2020<<. Error: Error restoring performance data
  • Within the archiver.log file the following error is seen:
2020-04-21 20:24:47,688 ERROR [default task-37710] ElasticCommon (ElasticCommon.java:538) - Exception while restoring snapshot
com.netapp.oci.es.ElasticsearchException: Exception while restoring snapshot
Caused by: java.util.concurrent.ExecutionException: RemoteTransportException[[SESKWPRDOCI01][127.0.0.1:9310][cluster:admin/snapshot/restore]]; nested: IndexNotFoundException[no such index];
    at org.elasticsearch.common.util.concurrent.BaseFuture$Sync.getValue(BaseFuture.java:265) ~[elasticsearch.jar!/:6.8.3]
    at org.elasticsearch.common.util.concurrent.BaseFuture$Sync.get(BaseFuture.java:252) ~[elasticsearch.jar!/:6.8.3]
    at org.elasticsearch.common.util.concurrent.BaseFuture.get(BaseFuture.java:94) ~[elasticsearch.jar!/:6.8.3]
    at com.netapp.oci.es.admin.ElasticAdminManager.restoreSnapshot(ElasticAdminManager.java:587) ~[elasticsearch-client.jar!/:?]
    ... 219 more
Caused by: com.netapp.oci.es.utils.ExceptionSurrogate: [org.elasticsearch.transport.RemoteTransportException] [SESKWPRDOCI01][127.0.0.1:9310][cluster:admin/snapshot/restore]
Caused by: com.netapp.oci.es.utils.ExceptionSurrogate: [org.elasticsearch.index.IndexNotFoundException] no such index
Note: The archiver.log file is located within your %SANscreen\wildfly\standalone\log directory
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
