NetApp Knowledge Base
OnCommand Insight Performance fails on multiple data sources due to Casandra challenges
9
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
Applies to
  • OnCommand Insight (OCI) 7.x
  • OnCommand Insight 7.2.x
Issue
OnCommand Insight performance acquisition fails for all data sources simultaneously.
In order to confirm this issue, the following error/errors is displayed in the following logs in the path:
%SANscreen_Home%\jboss\server\onaro\log Directory.
Cassandra_client.LOG:
Cassandra timeout during write query at consistency ONE (1 replica were required but only 0 acknowledged the write)
at com.datastax.driver.core.exceptions.WriteTimeoutException.copy(WriteTimeoutException.java:54)
at com.datastax.driver.core.DefaultResultSetFuture.extractCauseFromExecutionException(DefaultResultSetFuture.java:289)
at com.datastax.driver.core.DefaultResultSetFuture.getUninterruptibly(DefaultResultSetFuture.java:205)
at com.netapp.oci.cassandra.CassandraClient.execute(CassandraClient.java:627)
at com.netapp.oci.cassandra.CassandraClient.set(CassandraClient.java:211)
ACQ.LOG:
ERROR [DSM-pool-2-thread-149/Jade_Pearl [storageperformance]] com.netapp.oci.platform.common.interfaces.session.SessionCache (SessionCache.java:235) - Session Cache - Failed to communicate with the server ( PerformanceApiRemote) - unrecoverable error: Failed to store performance samples for dataSource: #, type: storage, key: [KEY_ID_NUMBER] cause: class com.datastax.driver.core.exceptions.ReadTimeoutException:Cassandra timeout during read query at consistency ONE (1 responses were required but only 0 replica responded
Caused by: com.datastax.driver.core.exceptions.ReadTimeoutException: Cassandra timeout during read query at consistency ONE (1 responses were required but only 0 replica responded)
DEBUG.LOG
WARN [SharedPool-Worker-2] 2016- AbstractLocalAwareExecutorService.java:169 - Uncaught exception on thread Thread[SharedPool-Worker-2,5,main]
:java.lang.RuntimeException: org.apache.cassandra.io.sstable.CorruptSSTableException: Corrupted:C:Program Files/SANscreen/cassandra/var/lib/cassandra/data/oci/general-fffffffffffffffffffffffffffffffffffffffffffffffflb-1-big-Data.db
Caused by: org.apache.cassandra.io.sstable.CorruptSSTableException: Corrupted: C:Program FilesSANscreencassandravarlibcassandradataocigeneral-fffffffffffffffffffffffffffffffffffffffffffffffflb-1-big-Data
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
