OnCommand Insight 7.x does not support devices using certificates with RSASSA-PSS signatures
Applies to
OnCommand Insight (OCI) 7.x
Issue
The following message is displayed on the Data Source page, after clicking "Poll Again":
The failure pattern in the logs will be similar to the following:
Failed to execute request: java.security.cert.CertificateException: Certificates do not conform to algorithm constraints and specifically: Caused by: java.security.cert.CertPathValidatorException: Algorithm constraints check failed on signature algorithm: 1.2.840.113549.1.1.10 The string "1.2.840.113549.1.1.10" is synonymous with "RSASSA-PSS". Java versions below 13.0 do not have full support of this standard.
