NetApp Knowledge Base
OnCommand Insight - All Data Sources fail acquisition with "Internal Error: Error" message
206
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
Applies to
OnCommand Insight (OCI) 7.3.x
Windows Server 2012 or later
Issue
All data sources fail with 'Internal Error'
The OCI acquisition log (RAU or Local) '\SANscreen\acq\log\acq.log' shows the following errors:
HTTP transport error: java.net.SocketException: No buffer space available (maximum connections reached?): connect
On the OCI Server's Host OS in '\SANscreen\wildfly\standalone\log\elasticsearch_client.log' you can see the following errors:
2019-10-08 17:35:51,270 ERROR [pool-10-thread-1] ElasticAdminManager (ElasticAdminManager.java:329) - Failed retrieving cluster information, error: No buffer space available (maximum connections reached?): connect
2019-10-08 17:35:51,270 ERROR [pool-10-thread-1] ElasticAdminManager (ElasticAdminManager.java:207) - Failed retrieving cluster information, error: Failed retrieving cluster information
2019-10-08 17:35:51,270 ERROR [pool-10-thread-1] ElasticCommon (ElasticCommon.java:544) - Failed retrieving cluster information
com.netapp.oci.es.ElasticsearchException: Failed retrieving cluster information
    at com.netapp.oci.es.admin.ElasticAdminManager.getClusterInfo(ElasticAdminManager.java:208) ~[elasticsearch-client.jar!/:?]
{Truncated}
    at java.lang.Thread.run(Thread.java:748) [?:1.8.0_172]
Caused by: com.netapp.oci.es.ElasticsearchException: Failed retrieving cluster information
    at com.netapp.oci.es.admin.ElasticAdminManager.getNodesInfo(ElasticAdminManager.java:330) ~[elasticsearch-client.jar!/:?]
    at com.netapp.oci.es.admin.ElasticAdminManager.getClusterInfo(ElasticAdminManager.java:201) ~[elasticsearch-client.jar!/:?]
    ... 10 more
Caused by: java.net.SocketException: No buffer space available (maximum connections reached?): connect
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
