NetApp Knowledge Base
OCUM fails to monitor a cluster having an empty failover group
141
Visibility:
Votes:
0
Category:
oncommand-unified-manager
Specialty:
om
Last Updated:
Applies to
  • OnCommand Unified Manager (OCUM) 9.5
  • ONTAP 9
  • Cluster has an empty failover group
Issue
  • OCUM fails to discover the cluster with the description "Cluster discovery failed. Rediscover the cluster after resolving the issue.".
  • The following java.lang.NullPointerException can be seen in au.log.
ERROR [pool-3-thread-2] c.o.s.a.f.d.BaseDataSource (AggregatedDataSourceErrorsException.java:152) -      Error 1 out of 1: <CLUSTER_MGMT_IP> [Internal error] - Internal error (Internal Error) java.lang.NullPointerException: network_failover_group_network_port_relationship key field 'network_port_name' may not be null.
    at com.onaro.sanscreen.acquisition.schema.KeyBase$KeyIDs.<init>(KeyBase.java:183) ~[au-package-common.jar:9.5.0-2019.04.J145]
    at com.onaro.sanscreen.acquisition.schema.KeyBase$KeyIDs.<init>(KeyBase.java:163) ~[au-package-common.jar:9.5.0-2019.04.J145]
    at com.onaro.sanscreen.acquisition.schema.KeyBase.<init>(KeyBase.java:17) ~[au-package-common.jar:9.5.0-2019.04.J145]
    at com.onaro.sanscreen.acquisition.datasource.netapp_ocie.model.ModelKeyBase.<init>(ModelKeyBase.java:21) ~[au-datasource-netappfoundation.jar:9.5.0-2019.04.J145]
    at com.onaro.sanscreen.acquisition.datasource.netapp_ocie.model.cmode.CModeNetworkFailoverGroupNetworkPortRelationship$NetworkFailoverGroupNetworkPortRelationshipKey.<init>(CModeNetworkFailoverGroupNetworkPortRelationship.java:49) ~[au-datasource-netappfoundation.jar:9.5.0-2019.04.J145]
    at com.onaro.sanscreen.acquisition.datasource.netapp_ocie.model.cmode.CModeNetworkFailoverGroupNetworkPortRelationship.<init>(CModeNetworkFailoverGroupNetworkPortRelationship.java:37) ~[au-datasource-netappfoundation.jar:9.5.0-2019.04.J145]
    at com.onaro.sanscreen.acquisition.datasource.netapp_ocie.model.cmode.CModeCluster.createNetworkFailoverGroupNetworkPortRelationship(CModeCluster.java:619) ~[au-datasource-netappfoundation.jar:9.5.0-2019.04.J145]
    at com.onaro.sanscreen.acquisition.datasource.netapp_ocie.builders.zapi.cmode.netappfoundation.NetworkFailoverGroupBuilder.buildIterInstance(NetworkFailoverGroupBuilder.java:47) ~[au-datasource-netappfoundation.jar:9.5.0-2019.04.J145]
    at com.onaro.sanscreen.acquisition.datasource.netapp_ocie.builders.zapi.cmode.netappfoundation.NetworkFailoverGroupBuilder.buildIterInstance(NetworkFailoverGroupBuilder.java:16) ~[au-datasource-netappfoundation.jar:9.5.0-2019.04.J145]
    at com.onaro.sanscreen.acquisition.datasource.netapp_ocie.builders.zapi.cmode.netappfoundation.IterBuilderBaseImpl.buildModel(IterBuilderBaseImpl.java:178) ~[au-datasource-netappfoundation.jar:9.5.0-2019.04.J145]
    at com.onaro.sanscreen.acquisition.datasource.netapp_ocie.builders.zapi.cmode.netappfoundation.CallableBuilder.call(CallableBuilder.java:59) ~[au-datasource-netappfoundation.jar:9.5.0-2019.04.J145]
    at com.onaro.sanscreen.acquisition.datasource.netapp_ocie.builders.zapi.cmode.netappfoundation.CallableBuilder.call(CallableBuilder.java:15) ~[au-datasource-netappfoundation.jar:9.5.0-2019.04.J145]
    ... 4 more
Wrapped by: com.onaro.sanscreen.acquisition.framework.datasource.DataSourceErrorException: Internal error
    at com.onaro.sanscreen.acquisition.datasource.netapp_ocie.builders.zapi.cmode.netappfoundation.ClusterBuilder.executeAndBuild(ClusterBuilder.java:233) ~[au-datasource-netappfoundation.jar:9.5.0-2019.04.J145]
    at com.onaro.sanscreen.acquisition.datasource.netapp_ocie.NetAppOCIEDataSource.doFoundation(NetAppOCIEDataSource.java:154) ~[au-datasource-netappfoundation.jar:9.5.0-2019.04.J145]
    at com.onaro.sanscreen.acquisition.netappfoundation.datasource.NetAppFoundationPackage.pollNow(NetAppFoundationPackage.java:199) ~[au-package-netappfoundation.jar:9.5.0-2019.04.J145]
    at com.onaro.sanscreen.acquisition.framework.datasource.BaseDataSource.run(BaseDataSource.java:263) [au-framework.jar:9.5.0-2019.04.J145]
    at com.onaro.sanscreen.acquisition.framework.mgmt.DataSourceManager$PollLogic.run(DataSourceManager.java:687) [au-framework.jar:9.5.0-2019.04.J145]
    at com.onaro.sanscreen.acquisition.framework.mgmt.scheduler.SchedulerTask.runLogic(SchedulerTask.java:91) [au-framework.jar:9.5.0-2019.04.J145]
    at com.onaro.sanscreen.acquisition.framework.mgmt.scheduler.Scheduler$LogicWrapper.run(Scheduler.java:271) [au-framework.jar:9.5.0-2019.04.J145]
    at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) [?:?]
    at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) [?:?]
    at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) [?:?]
    at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) [?:?]
    at java.base/java.lang.Thread.run(Thread.java:834) [?:?]
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
