NetApp Knowledge Base
OCUM 5.x: HTTP/HTTPS communicationfails with error due to incorrect CA configuration on ONTAP
317
Visibility:
Votes:
0
Category:
oncommand-unified-manager-core-package
Specialty:
legacy
Last Updated:
Applies to
OnCommand Unified Manager (OCUM) 5.x
Issue
  • API calls over HTTP or HTTPS are failing to the controller or cluster with the following error.
No permission to use 'hostsequiv' authentication, must be root
  • Command dfm host diag <HOST_NAME> returns the following error.
XML (https port 80) No permission to use 'hostsequiv' authentication, must be root
XML (https port 443) No permission to use 'hostsequiv' authentication, must be root.
  • Protection Manager job fails with the message including the followings.
    • Could not get live vol usage from filer for ..
    • Using data from the database instead ..
    • Failed to create secondary snapshot on ..
    • Unable to get a list of snapshots from the volume ..
New to NetApp?
