NetApp Knowledgebase
OCI EMC datasource fails with error:  Failed to login to SMI-S provider at
16
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
Applies to
  • OnCommand Insight 7.3.4 (OCI)
  • EMC Symetrix datasource
Issue
  • Cannot collect performance data from EMC symetrix datasource with error:
Failed to login to SMI-S provider at s00v09961398:5989/interop as user:admin
Performance error message :
Failed to execute Sym CLI symsan, because <?xml version="1.0" standalone="yes" ?> <SymCLI_ML> <Symmetrix> array_id </id> <port_record> <local_dir>01D</local_dir> <local_port>04</local_port>
<vendor>EMC Symmetrix</vendor> <array_id> array_id </array_id> <lun_count>1</lun_count> <port_wwn>port_wwn</port_wwn> </port_record> <port_record> <local_dir>01D</local_dir>
<local_port>05</local_port> <vendor>EMC Symmetrix</vendor> <array_id>array_id</array_id> <lun_count>1</lun_count> <port_wwn>port_wwn</port_wwn> </port_record> <port_record>
<local_dir>01D</local_dir> <local_port>08</local_port> <vendor>EMC Symmetrix</vendor> <array_id>array_id</array_id> <lun_count>1</lun_count> <port_wwn>port_wwn</port_wwn> </port_record>
<port_record> <local_dir>01D</local_dir> <local_port>09</local_port> <vendor>EMC Symmetrix</vendor> <array_id>array_id</array_id> ... [ Full content in recording file ]
  • in the datasource recording archive we see under foundation_<datasource_id>\<recording_id>\recording_sysman_<array_id>.txt file, at the bottom:
All available SYMSAN resources are currently in use. Please try again later
  </The tag "</SymCLI_ML>" did not match the expected "</Symmetrix>".
Error: XML parser error in state 8, found type 10.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
