NetApp Knowledge Base
OnCommand Insight Data Warehouse installation on Japanese Windows fails at the phase of 'Starting Reporting Engine'
53
Visibility:
Votes:
0
Category:
oncommand-insight-data-warehouse
Specialty:
oci
Last Updated:
Applies to
  • OnCommand Insight (OCI) Data Warehouse (DWH) 7.3.11
  • Installation on Windows OS with Japanese locale
Issue
  • OCI DWH installation fails at the phase of "Starting Reporting Engine ...".
Example:
  • install_oci_dwh_msi.log indicates that the reporting engine failed to start.
Example:
MSI (s) (78:14) [18:47:23:111]: Executing op: ActionStart(Name=Start_DWH_ReportEngine,Description=Starting Reporting Engine ...,)
Action 18:47:23: Start_DWH_ReportEngine. Starting Reporting Engine ...
MSI (s) (78:14) [18:47:23:111]: Executing op: CustomActionSchedule(Action=Start_DWH_ReportEngine,ActionType=9250,Source=D:\Program Files\SANscreen\,Target=**********,)
CustomAction Start_DWH_ReportEngine returned actual error code 1 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (78:14) [19:07:43:132]: Note: 1: 1722 2: Start_DWH_ReportEngine 3: D:\Program Files\SANscreen\ 4: **********
MSI (s) (78:14) [19:07:43:132]: Note: 1: 2205 2: 3: Error
MSI (s) (78:14) [19:07:43:132]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1722
Error 1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action Start_DWH_ReportEngine, location: D:\Program Files\SANscreen\, command: **********
MSI (s) (78:14) [19:10:49:792]: Note: 1: 2205 2: 3: Error
MSI (s) (78:14) [19:10:49:792]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1709
MSI (s) (78:14) [19:10:49:792]: Product: OnCommand Insight 7.3.11 (125) -- Error 1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action Start_DWH_ReportEngine, location: D:\Program Files\SANscreen\, command: **********
  • <Installation_Path>\SANscreen\cognos\analytics\logscogconfig.log shows errors like the following example.
Example:
16/02/2021,16:15:23,Info,========== Cognos Configuration =========
16/02/2021,16:15:24,Err,org.dom4j.DocumentException: Error on line 1345 of document  : 2 バイト UTF-8 シーケンスの 2 バイト目が無効です。, com.cognos.crconfig.data.DataManager.getConfigFileVersion(DataManager.java:946)com.cognos.crconfig.data.DataManager.getConfigFileVersion(DataManager.java:980)com.cognos.crconfig.data.DataManager.checkUpgrade(DataManager.java:610)com.cognos.crconfig.CRConfigConsole.begin(CRConfigConsole.java:125)
16/02/2021,16:15:24,Err,com.cognos.crconfig.data.DataManagerException: 始動設定ファイルを解析できません。, com.cognos.crconfig.data.DataManager.getConfigFileVersion(DataManager.java:949)com.cognos.crconfig.data.DataManager.getConfigFileVersion(DataManager.java:980)com.cognos.crconfig.data.DataManager.checkUpgrade(DataManager.java:610)com.cognos.crconfig.CRConfigConsole.begin(CRConfigConsole.java:125)
16/02/2021,16:15:24,Info,Silent exit with error code: 1
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
