NetApp Knowledge Base
OCI DWH installation fails at the phase of installing Cognos Server
75
Visibility:
Votes:
0
Category:
oncommand-insight-data-warehouse
Specialty:
oci
Last Updated:
Applies to
  • OnCommand Insight (OCI) Data Warehouse (DWH) 7.3.11
  • Installation on Windows OS
Issue
  • OCI DWH installation fails at the phase of "Installing Cognos Server ...".
Example:
  • install_oci_dwh_msi.log shows outputs like the following example.
Example:
MSI (s) (E0:D8) [10:52:00:785]: Executing op: ActionStart(Name=Install_DWH_Server,Description=Installing Cognos Server ...,)
Action 10:52:00: Install_DWH_Server. Installing Cognos Server ...
MSI (s) (E0:D8) [10:52:00:785]: Executing op: CustomActionSchedule(Action=Install_DWH_Server,ActionType=9250,Source=C:\Program Files\SANscreen\,Target=**********,)
CustomAction Install_DWH_Server returned actual error code 1 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (E0:D8) [10:57:06:516]: Note: 1: 1722 2: Install_DWH_Server 3: C:\Program Files\SANscreen\ 4: **********
MSI (s) (E0:D8) [10:57:06:516]: Note: 1: 2205 2:  3: Error
MSI (s) (E0:D8) [10:57:06:516]: Note: 1: 2228 2:  3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1722
  • <Installation_Path>\SANscreen\bin\log\install.cognos.server.log shows the following build error.
BUILD FAILED
C:\Program Files\SANscreen\bin\setup.xml:1190: The following error occurred while executing this line:
C:\Program Files\SANscreen\bin\setup.xml:1292: exec returned: -1
    at org.apache.tools.ant.taskdefs.ExecTask.runExecute(ExecTask.java:644)
    at org.apache.tools.ant.taskdefs.ExecTask.runExec(ExecTask.java:670)
    at org.apache.tools.ant.taskdefs.ExecTask.execute(ExecTask.java:496)
    at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:293)
    at sun.reflect.GeneratedMethodAccessor4.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
