No alerts or events from Active IQ Unified Manager for volumes when “Volume Space Full” event is breached
Applies to
- Active IQ Unified Manager 9.6 (and above).
- OnCommand Unified Manager 9.5 (and below)
Issue
- The
Volume Full
volume utilization event is not generated when volume utilization is above theVolume Full Threshold
- User receives
Volume Full
events intermittently in OCUM (OnCommand Unified Manager) - Note that it is possible that it does not trigger an alert if volume auto size is enabled, depending on the configuration. Verify the volume space utilization through cluster CLI and confirm that utilization is above
- It affects
Volume Nearly Full Threshold
too - The
Volume Nearly Full
volume utilization event is not generated when volume utilization is above theVolume Nearly Full Threshold
