NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
Java throws HeapDumpOnOutOfMemoryError exceptions for the acquisition unit service in API-S
167
Visibility:
Votes:
0
Category:
oncommand-api-services-api-s
Specialty:
om
Last Updated:
Applies to
  • OnCommand API Service 2.2P1 in Linux (API-S)
Issue
  • Java throws HeapDumpOnOutOfMemoryError exceptions
  • Large Heap dump files are created in /var/log/ocie with .hprof extension which fill up the filesystem
Example name of the file: java_pid9127.hprof
  • Executing command ps -aux | grep 9127 gives us the following output:
jboss     9127     1 99 Jun16 ?        203-01:22:05 java -Djna.tmpdir=/opt/netapp/data/tmp -Djava.io.tmpdir=/opt/netapp/data/tmp -D https.protocols=TLSv1,TLSv1.1,TLSv1.2 -Dlog4j.configurationFile=ocie-production.xml
-Donaro.home=/opt/netapp/essentials -Dcodebase= https://localhost:8443 -Djava.library.path=/opt/netapp/essentials/au/bin -Dacq.home=/opt/netapp/essentials/au -Djava.security.properties=/opt/netapp/essentials/au/conf/java.security
-Djava.rmi.server.hostname=localhost -Xmx2163m -Xms256m -XX:PermSize=64m -XX:MaxPermSize=256m -classpath /opt/netapp/essentials/au/conf:/opt/netapp/essentials/au/*:/opt/netapp/essentials/au/lib/*:/opt/netapp/essentials/au/lib/xml/xerces/*:
/opt/netapp/essentials/au/lib/xml/jdom/*:/opt/netapp/essentials/au/lib/jboss/client/*:/opt/netapp/essentials/au/lib/xml-3rd/*:/opt/netapp/essentials/au/lib/shared/* -Dno.trap=false -XX:+HeapDumpOnOutOfMemoryError -XX:HeapDumpPath=/var/log/ocie
-XX:ErrorFile=/var/log/ocie/au_error_%p.log -DJDBC_DRIVER=org.mariadb.jdbc.Driver -Djava.net.preferIPv6Stack=true -Djava.net.preferIPv6Addresses=true -verbose:gc -Xloggc:/var/log/ocie/gc_au.log -XX:+PrintGCDateStamps -XX:+PrintGCDetails
-XX:+UseGCLogFileRotation -XX:NumberOfGCLogFiles=10 -XX:GCLogFileSize=5M -XX:+UseG1GC -XX:+UseStringDeduplication -XX:+PrintTenuringDistribution com.onaro.sanscreen.acquisition.framework.Main start
  • We see that the XMX value is 2163m​​​​​​ for the acquisition unit service.
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
